RMS Hurdle Point 2 (hurdle_point2 with GEN1.FMX)
RMS Hurdle Point 2 displays all hurdle points (rates), including Total Rooms Sold and Delta details, for a property for a date range specified. The output is based on the activation of a Revenue Management license code. The report can be used by the hotel to check the Hurdle Point by Product Class/Yield Category for up to a year out and also indicates the Sell To Capacity values that have been set for the hotel in addition to providing you with inventory information.
From Date. Type or select the calendar button for the beginning date for the report results.
To Date. Type or select the calendar button for the ending date for the report results.
Preview. Select to preview the report in a PDF format.
Print. Select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
Date. Hurdle date.
Product Class. The Product Class assigned to the hurdle.
Hurdle Point. The amount of the hurdle rate. The value that must be reached in order for OPERA to display a rate code/room type on the rate grid.
Delta. Represents a monetary value, which is added to the hurdle rate for each additional room sold up to the ceiling. If the hurdle rate is set at $80.00 and the delta is $1.00, for the first room sold the rateable value needs to be $80.00 or more. For the second room the rateable value needs to be $81.00, for the third $82.00 and more up to the Ceiling at which time no additional delta values are added.
Sell to Capacity. This represents the maximum number of rooms to be sold in the room types linked to the YIELD CATEGORY. Once the Updsolds equals this level no further rooms for the date and Yield category may be sold.
Total Rooms Available (PMS). Total number of rooms that are available to be sold in the OPERA PMS module.
Individual Rooms Sold (PMS). Total number of individual rooms that have been sold in the OPERA PMS module.
Group Rooms Sold (PMS). Total number of group rooms that have been sold in the OPERA PMS module.
Total Rooms Sold (PMS). Total number of rooms that have been sold in the OPERA PMS module. This is calculated by adding the Individual Room Sold and Group Rooms Sold columns together.
