RMS Hurdle Point (hurdle_point with GEN1.FMX)
Note: We recommend printing this help topic with Portrait page orientation.
RMS Hurdle Point displays all hurdle points (rates) for a property for a date range specified. The output is based on the activation of a Revenue Management license code. The report can be used by the hotel to check the Hurdle Point by Product Class/Yield Category for up to a year out and also indicates the Sell To Capacity values that have been set for the hotel in addition to providing you with inventory information.
From Date. Type or select the calendar button for the beginning date for the report results.
To Date. Type or select the calendar button for the ending date for the report results.
Preview. Select to preview the report in a PDF format.
Print. Select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
