Userlog - Today's Checkout (nauserlogtodaycheckout with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Landscape page orientation.
User Log - Today’s Check Out Report displays all persons who checked out a guest for the current day, and runs as part of the Night Audit sequence. You can also print this report to see check out activity, to research check outs for a particular day, or to verify user checkout discrepancies.
Preview. Select to preview the report in a PDF format.
Print. select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
