previous
OXI_INVENTORY Parameters for OXI_HUB
In case your interface does not transmit full reservations and blocks both ways, inventory may be out of sync in either system and needs to be adjusted with the help of an inventory snapshot.
This is mostly sent from a OPERA PMS to OPERA ORS to update ORS with inventory changes at the property that have not been transmitted through the interface. This inventory snapshot contains the total sold count, overbooking level, and out of order rooms per day per room type. It further splits the sold counts into transient and block bookings, as well as definite and tentative bookings.
Example:  Screen OXI_INVENTORY group parameters.
Note: All parameters are set at the global level.
For example, CLS PMS receives reservations from ORS only and does not send its own reservations back. This means ORS does not know what the exact availability in the PMS is. To make sure ORS has exact sold counts and does not mistakenly overbook the hotel, CLS PMS will send an inventory snapshot to ORS, containing full reservation and block counts. When OXI_HUB receives this inventory snapshot it will directly update the availability tables for transient reservations and blocks for this property, and thus has an accurate picture of the number of rooms still available.
Parameter Name
Parameter Values
Direction of transmission where parameter applies.
Parameter Description
Recommended Setting
EXTERNAL PHYSICAL ROOMS
Y/N
-> Direction: Data from external system to OPERA.
The hotel may not allow the CRS to sell its full physical room capacity. Although the hotel has 100 rooms it may allow only 50 rooms to be sold by the CRS. In this case the physical rooms should be calculated from the inventory snapshot the external system sends to ORS to make sure only 50 rooms are considered. In this case the parameter would be set to Y. Set it to N if ORS has the entire physical room inventory from which the sold counts shall be calculated.
In ORS, physical room inventory may not be configured and should be updated by the external system.
The default setting is N for OXI-V6, OXI-V7, OXI-OPERA
INV SNAPSHOT
Y/N
-> Direction: Inventory derived from RTAV message
If reservations are not transmitted both ways in this interface but the external system creates reservations that affect its inventory, this parameter should be set to Y. In this case inventory will be updated in the OPERA based on data sent by external system. Set this parameter to N if it is not necessary to update the OPERA based on the data from the snapshot. This would be the case if reservations are transmitted fully both ways, or if the external system does not create any reservations on its own.
Set accordingly.
INV ROOMCLASS
N - No
OO - Overbook Only
YP - Physical Rooms for Suite
YS - Suite add a Single Unit
-> Direction: Data from Opera to external system
The external system may accept the Room Class totals in the RTAV message.
Set the parameter to 'YP' to include Room Class totals in the RTAV message. For Suites (Virtual Rooms), actual physical rooms comprising the Suite will be used for the Room Class totals.
Set the parameter to 'YS' to include Room Class totals in the RTAV message. Each Suite (Virtual Room) will be treated as a single unit for the Room Class totals.
Set the parameter to 'OO' to only send overbook counts in the RTAV message.
Set it to 'N', if Room Class totals are not to be included in RTAV messages.
When the General>Room Class and General>Component Rooms application functions are set to Y and the Inventory>INV_ROOMCLASS OXI Parameter is set to YS, Physical Room Types and Component Room Types cannot be attached to the same Room Class. Also, only 1 Component Room Type can be attached to a Room Class.
INV SNAPSHOT BLOCKS
Y/N
If blocks are not transmitted both ways in this interface but the external system creates blocks that affect its inventory, this parameter should be set to Y. In this case block inventory will be updated in the ORS inventory tables from the inventory snapshot sent by external system. Set this parameter to N if it is not necessary to update the ORS block inventory from the snapshot. This would be the case if blocks are transmitted fully both ways, or if the external system does not create any blocks at all.
This depends entirely on the nature of the interface.
INV SNAPSHOT RES
Y/N
If reservations are not transmitted both ways in this interface but the external system creates reservations that affect its inventory, this parameter should be set to Y. In this case transient reservation inventory will be updated in the ORS inventory tables from the inventory snapshot sent by external system. Set this parameter to N if it is not necessary to update the ORS reservation inventory from the snapshot. This would be the case if reservations are transmitted fully both ways, or if the external system does not create any reservations on its own.
UPL BLOCK INFO
Y/N
-> Direction: Data from OPERA to External System
Set it to Y if OXI needs to send the block information (block code, ded type, blocked/sold count) to the external system. Set it to N if OXI need not send the block information to the external system.
Set accordingly.
See Also
