previous
OXI_STAYS Parameters for OXI_HUB
Note: All parameters are set at the global level.
Parameter Name
Parameter Value
Direction of transmission where parameter applies.
Parameter Description
Recommended Setting
ALTERNATIVE STAY PROFILE SEARCH
ENABLED
DISABLED
-> Direction: Data from external system to OPERA.
Valid values are ENABLED and DISABLED. ENABLED means that profile for the stay will be searched in ORS by its reservation confirmation number or membership number as alternative to the current subscription search before setting values in the stage table.
DISABLED means it will follow the usual process and match stay profiles by their existing subscription ID.
When enabled, allows stay records incoming to OCIS to be matched with not only a subscription ID but also with an alternative, such as Confirmation No# or Membership No#. For migrated stay records from properties that are NOT subscribed to OCIS via an interface, setting the parameter value to ENABLED can be especially useful.
BYPASS CONVERSION
CRMVBNSX
The values CRMVBNS indicate that if conversion fails for a particular stay data field, the record is not staged and the value from the external system in the ORS stay record. Values are:
C – Currency Code
R – Rate Code
M – Market Code
V – Revenue Type
B – Membership Type
N – Channel Code
S – Source Code
As a sample:  if the parameter has the values MS, then in case conversion for incoming market M) and source code (S) fails, the record is not staged and the stay still is inserted into ORS. In our sample C has not been selected. This means if no conversion for channel code (N) is found, the stay record id staged until conversion is updated. X is used in case the parameter is inactive.
Set variables as needed to ensure stay record is processed even is conversion fails.
The default setting is X for OXI-V6, OXI-V7, OXI-OPERA
BYPASS VALIDATION
ENABLED
DISABLED
Valid values are Enabled and Disabled. Enabled means that external value will be inserted in the stay record without validation. Disabled means that the validation will be performed first and external value inserted if it passes the validation.
Set Enabled if Stay data is just to be inserted as is from external system.
Set Disabled if Stay data is to be converted to receiving systems value and or Staged if conversion is not met.
Default is Disabled
PRIMARY MEMBERSHIP
ENABLED
DISABLED
Valid values are Enabled and Disabled. Enabled means all memberships sent by the external system will create a membership transactation in OPERA.
Example for V6:   If MEMBERNR is populated in the reservation and the guest belongs to the Primary Membership then the system will automatically create the Membership Transaction for the Primary Membership.
Disabled means that memberships transactions will only be generated based upon values sent in FFPTYPE, FFPNUM, FGPTYPE and FGPNUM on the reservation by the external system.
Set according to business needs.
Default is Disabled
See Also
