Profile Statistics (profilestats with RESORS1.FMX)
Note: When printing this Report help topic, we recommend printing with Landscape page orientation.
This report displays by profile with Room Nights, Avg. Rate, LOS (Length of Stay) and by number of People. The report is based on the Stay Data Analysis by Profile.
Property. Select the property(s) you are interested in viewing.
Date Range. Enter the From/To Date range for the profile statistics you want to view. The From Date is based on the Arrival date and is what the system specifically searches.
Filter. Select the Rate Code(s), Source Code(s) and Market Code(s) you want the report filtered by.
Preview. Select to preview the report in a PDF format.
Print. Select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
