Profiles with Outdated PCC (ors_pcc with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Portrait page orientation.
This report displays the company or travel agent profile name and its channels and properties. Each channel and property having pseudo city codes (PCC) appear. You can also filter for Inactive From/To PCC dates.
The access codes and pseudo city codes were created from the Travel Agent or Company Profile screens>Options>Access Codes. For more information, refer to the topic Access Codes.
Profile. Enter the company or travel agent profile name in the Profile field; or select the down arrow to open the Profile Search screen. At the Profile Search screen, enter the profile name or the Corp. or IATA number. Select OK.
From Date/To Date Entered. Enter the date range from when the PCC request was entered.
From Inactive/To Inactive Date. Enter the date range for when the PCC was inactive.
Preview. Select to preview the report in a PDF format.
Print. Select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
