Catering Pace / Progress Reports (REP_CATERING_PROGRESS.REP with REP_CATERING_PROGRESS.FMX)
This report displays the catering production for a certain time period compared to budgeted covers and revenue for the same stay date period and another comparison to the production for the same stay date range last year. The produced covers, revenue and average checks are grouped by stay date periods (either calendar month or fiscal period, depending on the hotels configuration). The report can be run for a limited production period; i.e., 01 June 2003 to 30 June 2003 which would only show the production during that time frame. Alternatively the report can be run with the production date range left blank, which would represent catering covers and revenue for the stay date range at the moment of printing (also known as On-the-Books).
This report operates without a defined credit status and therefore will only ever report on the last status that an event is on during the production period. For example, if the report is run for production period June 2003 and we have an event that was created with 100.00 USD food revenue on status TEN on 02 June 2003, turned DEF on 10 June 2003 and became ACT on 20 June 2003, the 100.00 USD food revenue will ONLY appear in the column for status ACT, which was the LAST status this event was on in the reported production period. This is important to note when comparing this report to other catering production reports like the Catering Production report (REP_CATERING_SUMMARY) which operates with a credit status and could therefore count the event twice, once in the defined credit status (usually DEF) and once in the last status (here ACT) if the event passed both statuses in the production period.
Note: When printing this Report help topic, we recommend printing with Landscape page orientation.
Note: This report requires that the user be granted the EVENT PRINT permission in the selected property to run the report. Also, the Property LOV in this report is further limited by the properties to which the user has the appropriate access granted.
Property. Available when OPS_MHT2 license is active. Choose the property for which the report should be printed.
Arrival Period (Arrival Start/End Date). The event date range that should be covered in this report.
Production Period (Production Begin/End Date). Defines the date range for which event changes should be recorded. Each change that is done to an event status or to event revenue is recorded in a specific production change log. The Production Date Range filter will scan the entries in this production change log to search for any event changes that fall under the other criteria that have been selected on the filter form. By the nature of this date range filter, only dates in the past are valid entries, because there cannot be any entries in the event change log after the current business date. To illustrate the above, an event that gets created on status TEN in April 2003 with event date in October 2003 can turn to status DEF in June 2003. In the above scenario there would be two entries in the change log for this event, one for the creation of the event on status TEN in production period April 2003 and one for the status change to DEF in June 2003.
Group Each Period by (Market Segment). This field will sort each period by the market segment(s) selected here. When S&C Catering Budget information is configured, and the Catering Pace Report (rep_catering_progress) is run without a Market Segment filter, the budget information will print on the report with a variance to the booked numbers. However, when the report is run with a Market Segment filter selected, the budget information will not print.
Event Status 1 & 2. Allows a selection of up to two different status columns to print onto the report. Please keep in mind that, as explained above, this report will ONLY report an event under the last status that it was in the production period. If an event turned DEF and ACT in the selected production date range, it will on this report ONLY be reported in the ACT column, not in both DEF and ACT. Please note that the first column of the report will always print the ACT status and the second column will be calculated from the ACT column plus values from the status selected in status filter 1. In most set-ups it would therefore make most sense to select the status just prior to ACT in the status filter 1 i.e. DEF.
Status1 & 2 – Last Year . Allows the selection of up to two different status columns to print for the production in the same production date range and stay date range one year back. It makes most sense to select the same status code that got selected for the current production period in order to compare last year’s production to the current production within the same status codes.
Covers – Event Type. Select the Event Types that should be used for calculating covers and average check.
RevPor. – Rev Type. Select the Revenue Types that should be used for calculating Revenue Per Occupied Room. The figure in the report will be calculated by dividing the sum of these revenue types by the number of blocked rooms for those groups. If the business blocks status is in an actual status, the picked-up rooms will be used instead of blocked rooms.
Avg Check – Rev Type. Select the Revenue Types that should be used for calculating the Average Check. The figure in the report will be calculated by dividing the sum of these revenue types by the number of covers.
Note: When the application parameter Use Forecast Value Only is set to Y and an Event has an F&B Minimum Rate Code attached, forecasted revenue will not be reported or recorded for the Revenue Types that are configured to contribute to the F&B Minimum. If the Rate Code is changed to one that does not require a minimum and expected revenue has not been added to those revenue types, the forecasted revenue for revenue types configured to contribute to the F&B Minimum will be reported.
Variance based on Status 1, 2 or Both. Which status column should the variance to budget be calculated for on the report. Typically this variance would be compared to a combination of DEF and ACT bookings.
Print Exclude from Forecast Event - Both/Yes/No. Select this option to either include or exclude certain events. When Both is selected all qualifying events will print. When Yes is selected, only events that have had the Exclude from Forecast Reports flag checked will print (the Exclude from Forecast Reports flag is accessible on the Events Screen Details tab). When No is selected only events that have NOT been marked as Exclude from Forecast Reports will print.
Preview. Use the preview option to view the generated output of this report in PDF format.
Print. Use the Print button to print the report to the selected output.
File. Prints the generated report output to an *.rtf file.
Close. Closes this report screen.
The first four columns of the report show the produced catering revenue by revenue type, total catering revenue, covers, average check and revenue per occupied room by status for each calendar month in the selected stay date range. The first column is hard-coded to always show the ACTUAL produced figures. The second column will add the production of status 1 defined in the report order form to the ACTUAL produced figures and show the total of those two statuses. The third and fourth columns will show the production of statuses 1 and 2 as defined on the report order form respectively.
Again, note that each event will only ever be counted for one of the selected status codes, namely the last one that it was on at the end of the production period. No event will be recorded under the DEF and ACT status columns, even if it passed through the DEF status into the ACT status during the selected production period.
The next two columns of this report represent the budget figures that have been entered for the stay date range that the report is run for, as well as the difference of the current produced figures to the budget figures, depending on which status column has been selected on the filter form for comparison.
The next two columns show the production of the same production period exactly one year back. If the current production period is June 2003 for stays dates June 2003 to December 2003, the last year columns will calculate the production in June 2002 for stay dates June 2002 to December 2002.
The following two columns show the budget for last year and the variance of the produced figures versus the budgeted figures last year.
The last column will show the actual figures produced last year.
Also note that forecast figures are calculated as event production for this report if no expected, guaranteed or actual figures exist for a specific revenue type. For example, if an event had forecasted revenue for 500.00 USD Room Rental, 1000.00 USD for Food and 100.00 USD for Decoration, but only the function space is booked at a rate of 450.00 USD when the event becomes DEF, the revenue recorded in this report as production on the status change will still be 450.00 USD Rental, 1000.00 USD Food and 400.00 USD Decoration.
Note: Currency values in this report can be represented by an abbreviation when the application setting General>Currency Divisor Value is configured. For example, if values recorded in this report are too long to accurately display in the allotted space, such as 354,000, the currency divisor value set to K for 1000 can change that display to 354K so that all values over 1000 will display shortened and without decimals. The divisor value can also be set to M, which will shorten all amounts over 1 million by 5 digits and print them without decimals.
