Reservation by Rate Code (resvratecode with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Landscape page orientation.
Reservation by Rate Code is a past-date report that displays the number of reservations per reservation date, property and rate code.
Property. Select the property(s) you want to view.
From Date/To Date. Select the beginning and end date range for the reservations you want to view.
Rate Code. Select the rate codes(s) for the reservations you want to view.
Preview. Select to preview the report in a PDF format.
Print. Select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
