Registration Card - Schedine (schedine with RES9.fMX)
Note: When printing this Report help topic, we recommend printing with Landscape page orientation.
The Registration Card Report displays all registration cards and corresponding information that have been printed for a given date. This report is specific to countries located in Italy, and must therefore be manually added to the Reports Menu.
Arrival Date. Date. Manually enter, or select the Calendar button to choose, the arrival date for the report. Defaults to the current business date.
Group. Select the Group from the single select list of values.
Preview. Select to preview the report in a PDF format.
Print. Select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
Note: If your property is included in a database schema that has one or more properties in Korea (KR) country mode and you have initiated and completed the associated encryption process, the Date of Birth information is masked with X's by default.
