Country Specific Statistics (stat_countryspec with GEN1.FMX)
Note: When printing this Report help topic, we recommend printing with Landscape page orientation.
The Country Specific Statistics Report meets the reporting requirements for properties located in the countries of Norway and Sweden. The report is based on the country code placed in the Country field in Property details. For properties located in Norway, the field Print Group appears on the Market Code configuration screen. The list of values is hard coded to include Business, Leisure and Conference. Only those properties requiring the print group information need to configure this report.
Preview. Select to preview the report in a PDF format.
Print. Select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
