Start the emulator or simulator you wish to use.
In the menu, select the Application > Deploy > New Deployment Profile.
Select MAF Android as the Profile Type and keep the default name.
Then click OK.
In the menu, select Application > Deploy > Android2.
Then in the Deploy window, select Deploy application to emulator and click Finish.
Watch the Deployment window for the deployment to complete.
In this part of the tutorial, you create a deployment profile for the Android Emulator or iOS Simulator you are deploying to. In this step the instructions and images are for the Android Emulator, but the same steps will work for the iOS Simulator.
In this section, you open and run a web service that you will use in your application. You then create a data control based on the web service and consume the data control from your application.
Find and invoke the SummitLocalDB application. It may be on the second page of applications.
After it loads you should see the records retrieved from the web service.
To see the records retrieved from the local database, find the Settings icon and turn on airplane mode.
Navigate back to the application, and click the Refresh button and the records retrieved from the local database will displayed.
At this point the tutorial is complete.
Expand all | Hide all
Part 1: Initialize a SQLite Database and write data access code
