在控制台上输入有效的用户名和密码以登录到 CLI。例如,如果我们刚刚完成了上面的初始配置步骤,我们的 CLI 登录将为:
caji console login: root Password: To setup your system, you will be taken through a series of steps; as the setup process advances to each step, the help message for that step will be displayed. Press any key to begin initial configuration ...
