Supplemental
Software Component Options
Oracle System Assistant provides an application, called
InstallPack to install platform Supplemental Software components.
InstallPack has two options to install Supplemental software:
The following table identifies the optional Supplemental Software components.
Table 2 Optional Supplemental Software
Qlogic Drivers
Installs Qlogic drivers (FC, FCoE, NIC, iSCSI) using a
wizard.
Typical
Emulex Drivers
Installs Emulex drivers (FC, FCoE, NIC, iSCSI) using a
wizard.
Typical
Oracle Hardware Management Pack
provides tools to help you manage and configure your server. It enables you to:
Use a management agent at the operating system level to enable in-band monitoring of your
server hardware over Simple Network Management Protocol (SNMP). You can use this information to
integrate your server into your data center management infrastructure.
Use a management agent to enable in-band monitoring of your server's storage devices,
including RAID arrays. You can view this information from the Oracle Integrated Lights Out Manager
(ILOM) web interface or command-line interface (CLI).
Use a BIOS configuration tool, which runs on the host operating system and configures the host
BIOS CMOS settings, host boot order, and some service processor (SP) settings.
Use IPMItool to access the server's service processor via the IPMI protocol and perform
management tasks.
Custom
Intel Network Connections PROSet for Windows
Enables additional network features, including NIC Teaming.
Typical
LSI MegaRAID StorCLI
Enables you to configure, monitor, and maintain
RAID on the SAS 3 internal RAID host bus adapter (HBA).
Typical
LSI MegaRAID Storage Manager for Windows
Typical
Intel Chipset Software Installation Utility
Automatically tells you if you need to update your chipset INF files and prompts you to
install the files.
Typical
