Table 32. NotifyGeneric Notification Type
SWEICanInvokeMethod |
Enables the refresh button. |
SWEICtlDefChanged |
Modifies the definition for a control. You can customize Siebel Open UI to dynamically modify the definition that a control uses. For example, modifying a definition from JavaScript text box to a JavaScript combo box. |
SWEIPrivFlds |
Specifies a list of private fields. For example, the Find controls that Siebel Open UI displays in a dialog box. A private field is a type of field that only allows the record owner to view the record. For more information, see Siebel Object Types Reference. |
SWEICanUpdate |
Specifies to display data-driven, read-only behavior. |
SWEICanNavigate |
If a list applet displays zero records, and if the user adds a new record, then the SWEICanNavigate subtype displays the drilldown links. |
SWEIRowSelection |
Sends the set of selected rows that exist in the current set of records to a list applet. You can use the following syntax in the decoded array: argsArray[0] = applet name argsArray[1-x] = value
where:
- applet name identifies the name of the applet where Siebel Open UI sends the notification.
- value is one of the following:
- 1. Indicates selected.
- 0. Indicates not selected.
SWEAInvokeMethod |
Adds an operation in the life cycle that the InvokeMethod method uses. For example, assume you configure an OK button in an association applet, and that this button closes a dialog box. You can use the SWEAInvokeMethod subtype to configure this button to make a subsequent call to the CreateRecord method if the user clicks OK. You can use the following syntax in the decoded array: argsArray[0] = applet argsArray[1] = method
where:
- applet identifies the name of the applet that Siebel Open UI calls during the first operation.
- method identifies the name of the subsequent method that Siebel Open UI calls.
For more information, see InvokeMethod Method for Presentation Models. |
DeletePopup |
Deletes a popup applet. The DeletePopup subtype does not close an applet in the user interface. You can use ClosePopup to close an applet. |
SetPopupBookmark |
Sets the context for a popup bookmark to use the state of the parent applet that resides on the Siebel Server. |
GetQuickPickInfo |
Sends the values of a picklist to an applet. You can use the following syntax in the decoded array: argsArray[0] = placeholder argsArray[1] = view argsArray[2] = applet argsArray[3] = identifier argsArray[4] = control argsArray[5-x] = string
where:
- placeholder is a placeholder array that you can you use.
- view identifies the name of the view where Siebel Open UI displays the picklist.
- applet identifies the name of the applet where Siebel Open UI displays the picklist.
- identifier identifies the HTML identifier of the control that requested the picklist values.
- control contains one of the following values:
- true. Picklist is associated with the control.
- false. Picklist is not associated with the control.
- string contains the values of the picklist.
BegRow |
Sends the starting row that the Object Manager uses to display the current row in the client. You can use the following syntax in the decoded array: argsArray[0] = applet name argsArray[1] = value
where:
- value contains the value of the beginning row.
GetCurrencyCalcInfo |
Gets a currency notification from the currency metadata. |
GetCurrencyCodeInfo |
Gets a currency notification from specific currency data. |
CloseCurrencyPickApplet |
Sends a notification to close a currency applet. |
ClosePopup |
Notifies an applet that Siebel Open UI is closing a popup that is currently open on this applet. You can use the following syntax in the decoded array: argsArray[0] = applet
where:
- applet identifies the name of the applet.
