Table 34. Property Set Types That Siebel Open UI Supports
SWE_PROP_NC_PDQ_INFO |
Child property set for the Predefined Query (PDQ). It includes the list of PDQ items that Siebel Open UI displays. It uses the following properties:
- SHOW_EMPTY_STRING. Display an empty PDQ entry.
- SWE_PROP_NC_CAPTION. Identifies the caption that Siebel Open UI displays for the PDQ.
SWE_PROP_NC_VISIBILITY_INFO |
Defines the beginning of the visibility property set. It uses the following properties:
- SWE_PROP_NC_ITEM_INFO. Identifies the item start property.
- SWE_PROP_NC_SCREEN_NAME. Identifies the screen name.
- SWE_PROP_NC_VIEW_NAME. Identifies the view name.
- SWE_PROP_NC_CAPTION. Identifies the display value for the caption.
- SWE_PROP_NC_SCREEN_TAB_ICON. Identifies the icon name to use for the screen tab.
You can use the VisDropDownItem property as the predefined bubbled handler to do user interface binding. |
SWE_PROP_NC_SCREENCTRL_INFO |
Defines information for the first level in a screen. It uses the all the same properties that the SWE_PROP_NC_VISIBILITY_INFO property set uses except it does not use the SWE_PROP_NC_ITEM_INFO property. You can use the GetTabInfo property as the predefined bubbled handler. |
SWE_PROP_NC_FLOATING_TAB_INFO |
If Siebel Open UI already displays a screen, and if the user clicks an empty tab, then SWE_PROP_NC_FLOATING_TAB_INFO adds a new tab. It uses the GetTabInfo property. |
SWE_PROP_NC_AGGREGATE_INFO |
Describes Amazon link information. It uses the GetTabLinkInfo property. It uses the following properties:
- SWE_PROP_NC_VIEW_NAME. Specifies the view name that Siebel Open UI displays.
- SWE_PROP_NC_CAPTION. Specifies the caption that Siebel Open UI displays.
SWE_PROP_NC_SUBDETAIL_INFO |
Specifies information for the fourth level link. It uses the same properties that the SWE_PROP_NC_AGGREGATE_INFO property set uses. |
SWE_PROP_NC_DETAIL_INFO |
Specifies the view tab information that Siebel Open UI displays to start. It uses the GetTabInfo property. It uses the following properties:
- SWE_PROP_NC_VIEW_NAME. View name that Siebel Open UI displays.
- SWE_PROP_NC_CAPTION. Caption that Siebel Open UI displays.
You can use the following properties as predefined bubbled handlers:
- GetDataReloadDirty. Specifies the flag property.
- GetSelectedTabKey. Selection of tabs.
- GetSelectedTabLinkKey. Selection of links underneath tabs.
- GetTabInfo. All tabs.
- GetTabLinkInfo. All links.
