Configuring Siebel Open UI > Reference Information for Siebel Open UI > Life Cycle Flows of User Interface Elements > Life Cycle Flows That Handle User NavigationThis topic describes the life cycle flows that Siebel Open UI uses when the user navigates through various items in the client. Flow That Siebel Open UI Uses if the User Clicks an Applet in a ViewFigure 43 illustrates the life cycle flow that Siebel Open UI uses if the user clicks an applet in a view. Flow That Siebel Open UI Uses if the User Navigates to a ViewFigure 44 illustrates the that Siebel Open UI uses if the user navigates to a view. Flow That Handles Focus Changes in Form AppletsFigure 45 illustrates the life cycle flow that Siebel Open UI if the focus changes for a field in a form applet. For example, if the user tabs out a field, clicks outside the field, minimizes the window, saves the record, and so on. Flow That Handles Focus Changes in List AppletsFigure 46 illustrates the life cycle flow that Siebel Open UI if the focus changes for a field in a list applet. For example, if the user tabs out a field, clicks outside the field, minimizes the window, saves the record, and so on. |
| Configuring Siebel Open UI | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
