| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can change time zone in the Calendar screen and the Calendar views. You might want to change the calendar time zone if you travel between time zones.
Note: You can set a default time zone for your calendar in your user preferences. For more information, see "Setting a Default Time Zone". |
To change the time zone for the calendar
Navigate to the Calendar screen.
Click ... (Advanced Calendar Settings).
The Settings dialog box appears.
From the drop-down list for the Time Zone field, choose the appropriate time zone, and click OK.
The calendar times appear in the time zone that you select.
