| Siebel Customer Relationship Management Siebel Fundamentals for Siebel Open UI Siebel Innovation Pack 2014 E52425-01 |
![]() Previous |
![]() Next |
View PDF |
When working with your team members, you might want to allow them to see your activities or to add activities to your schedule. To grant other people access to your calendar, you add team members in the Access List, and give them view or update privileges.
Note: Calendar sharing can result in the routing of numerous activities to mobile clients. |
To give others access to your calendar
Navigate to the Calendar screen.
On the link bar, click Access List.
The Calendar Access list appears.
Click New.
The Add Employees dialog box appears.
Select the record for an employee, and then click OK.
The Calendar Access list appears again. The employee you select appears in the list, and that employee can now view your calendar.
(Optional) To allow the employee to add activities to your calendar, select the Allow Updates check box.
