| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
When you create a new calendar activity, a number of fields are filled in with default values. These values are shown in Table 12-2 as they appear in preconfigured Siebel applications.
Table 12-2 Calendar Detail Field Default Values
| Field | Default Value |
Type |
Appointment |
Start |
Current time rounded up to the next calendar interval. For example, if it is 11:02 A.M. and the daily calendar interval specified in your user preferences is 15 minutes, the start time defaults to 11:15 A.M. (If you created the new calendar activity by drilling into a time value along the left side of the Daily or 5 Day Weekly view, the time will be defaulted based on the value you drilled into, regardless of the current time.) |
Duration |
Default value, in minutes, as specified in your user preferences. |
End |
Start time plus the value found in the Duration field. |
Owner |
Your Siebel applications user name. |
