| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
When you create a recurring activity, the Repeat Until field defaults to a predetermined value based on what you select from the Repeat Frequency drop-down list. You can change this value as desired. Table 12-3 shows the default values of the Repeat Until field. For more information about creating recurring activities, see "Creating Recurring Calendar Activities".
