| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
You can change the date or time zone in any of the Calendar views. This is helpful if you frequently travel in a number of time zones.
You can change the date in any of the Calendar views.
To change the date
In the current Calendar view, click the arrow to the left of the date field to navigate to an earlier date. Click the arrow to the right of the date field to navigate to a later date. You can also click the calendar select button to launch the calendar dialog box from which you can pick a date.
The calendar displays activities for the selected date.
Note: You can set a default time zone for your calendar in the User Preferences screen. For more information, see "Setting Time Zone Preferences". |
