| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
You can run queries to find activities in your calendar.
To query your calendar
In the Activities screen, create and save the query.
Navigate to the Calendar screen and select the saved query from the Queries drop-down list.
For more information about queries, see Chapter 8, "Using Query to Locate Information"
