| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
A selection dialog box can contain many records. You might find it necessary to search for the information you need. Use the Find drop-down list and the Starting with field for full or partial-text searches on one column.
The Siebel application automatically assumes a wildcard exists at the end of text entered in the Starting with field. This means that if you search for Siebe, the Siebel application looks for all words beginning with the letters Siebe.
Caution: Any spaces you enter in the Starting with field when performing a find will be searched for, which is not similar to performing a query. For example, if you are looking for a contact with the last name Smith, and enter Smith followed by a space in the Starting with field, any contacts with the last name Smith will not be found. This is because the Siebel application is looking for each character (all the letters in Smith and a space). |
To find a specific record in a selection dialog box
In the selection dialog box, from the Find drop-down list, select the column you want to search on.
In the Starting with field, type the text you are looking for.
Click Go.
The records matching your criteria appear.
