| Siebel CRM Fundamentals Siebel Innovation Pack 2014 E24770-01 |
![]() Previous |
![]() Next |
View PDF |
You can query within a selection dialog box just as you would within a list or form. This allows you to search for specific information from one column or from several columns at one time.
To query in a selection dialog box
In the selection dialog box, click Query.
A blank row or a blank form appears in the selection dialog box.
Enter your query criteria.
The Siebel application automatically assumes a wildcard exists at the end of text entered in the query fields. This means that if you search for Siebe, the Siebel application looks for all words beginning with the letters Siebe.
Click Go.
The records matching your query criteria appear.
Related Topic
