Siebel Pricing Administration Guide > Siebel Pricer Technical Reference > Miscellaneous Pricing Workflows >
PSP Waterfall Synch to DB Workflow
The PSP Waterfall Synch to DB workflow, as shown in Figure 44, writes waterfall records to the database according to input from the data map object.
Figure 44. PSP Waterfall Synch to DB Workflow
Table 83 lists describes the step in the PSP Waterfall Synch to DB workflow with the business service and method that is called.
Table 83. Steps of the PSP Waterfall Synch to DB Workflow
Sync Waterfall |
Business Service |
PSP Waterfall Service |
WriteWaterfall |
Not applicable |
Writes waterfall records to database. |
