| Siebel Product Administration Guide > Siebel Configurator Rule Assembly Language > About Operators in Rule Assembly Language > Arithmetic Operators in Rule Assembly Language
 Arithmetic operators expect numeric operands and produce a numeric result. They are most frequently used in sub-expressions. The following top-level expression means that the quantity of item C in the solution must be the same as the sum of the quantities of items A and B.  ==(+([A],[B]),[C]) Assuming no other constraints on item A, B, or C; if you add A or B to the solution, then C will be added as well to match the sum. If you add a large number of C's, the Siebel Configurator engine will add A and B in arbitrary quantities so that their sum equals the amount of C.  When used in sub-expressions, these operators must return a numeric result. If a sub-expression returns a logical result, true is interpreted as a 1, and false is interpreted as a 0. In the example above, if B is an expression that returns the logical result true, then the expression is equivalent to the following: ==(+([A],1),[C])  Arithmetic operators are shown in Table 33.
Table 33.	Arithmetic Operators
    | Addition | +(A, B) | Sum of A and B. A and B can be items or sub-expressions. Result is floating point if A or B is floating point. |
    | Subtraction | -(A, B) | Subtracts B from A. A and B can be items or sub-expressions. Result is floating point if A or B is floating point.  |
    | Negation | -(A) | Additive inverse of A. Uses only one operand. A can be an item or expression. |
    | Multiplication | *(A, B) | Product of A and B. Result is floating point if A or B is floating point. A and B can be items or sub-expressions. |
    | Division | /(A, B) | Quotient of A divided by B. Truncates ratio to integer if both A and B are integers. Result is floating point if A or B is floating point. A and B can be items or sub-expressions.  |
    | Modulo | %(A, B) | Remainder of A divided by B. For example, %(1900, 72) results in 28. If A or B is floating point, the value is first rounded to the nearest integer; then the remainder is computed as for integers. A and B can be items or sub-expressions.  |
    | Minimum | min(A, B) | Result is the smaller of A and B and is floating point if A or B is floating point. A and B can be items or sub-expressions.  |
    | Maximum | max(A, B) | Result is the larger of A and B and is floating point if A or B is floating point. A and B can be items or sub-expressions.  |
 The following operators, shown in Table 34, also take numeric arguments and produce numeric results. Use them to control numeric accuracy or change numeric characteristics.
Table 34.	Additional Arithmetic Operators
    | Quantity | qty(A) | Result is the quantity of A rounded to nearest integer. For example, if A is 6.7, returns 7. If A is 6.3, returns 6. A can be an item or sub-expression. Useful only with resources.  |
    | Integer | int(A) | Truncates A down to an integer. For example, if operand is 6.7, returns 6. A can be an item or sub-expression. |
    | Float | flo(A) | Converts A to floating point. Same as multiplying operand by 1.0. A can be a sub-expression. Not useful with resources. |
    | Absolute value | abs(A) | Returns the absolute value of A. A can be an item or sub-expression. |
    | Sign test | sgn(A) | Returns -1 if the quantity of A <0, 0 if A=0, 1 if A>0. A can be a sub-expression. |
