Siebel Product Administration Guide > Product Attributes with Business Component Domains > Process of Creating an Attribute with a Business Component Domain > Setting Up Multiple Fields for DisplayYou can group attributes together so that selecting a record from a pick applet for one attribute populates several attributes. You do this by defining additional PickMap UI properties on an attribute. These additional UI properties define how to populate the other attributes. This task is a step in Process of Creating an Attribute with a Business Component Domain. The attribute on which you define PickMap01 is called the primary attribute. The user selects a value for this attribute and this causes the values for the other attributes to be selected automatically. The Product Administrator has created a product with components called Premier Service Package. This product has been assigned to a product class that has the attributes Account, Location, and Opportunity defined on it. These attributes have been added to a group in the User Interface view and will display in selection pages. The Product Administrator wants users to be able to select an account name when configuring the product. When they do, the Account Administrator wants to automatically populate the Location attribute with the state in which the account is located. To do this, the Product Administrator must define the following UI properties on the Account attribute:
The Account and Location attributes display with a text box next to them in the configuration selection pages. When the user clicks the select button and chooses an Account name, it is transferred to the Account field and the state name is transferred to the Location field. Table 6 shows how to use the predefined UI properties to set up multiple fields for display. To set up multiple fields for display
| Siebel Product Administration Guide | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
