| Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs for the Complex Object Manager > GetPossibleDomain Method
 This method retrieves selectable items from the configuration engine for a port Input Arguments
ObjId. The unique identifier of the complex object root (for example, Quote ID).
RootId. The unique identifier of the complex object root (for example, Quote Line Item row id).
(Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
Parent Path. The item parent path.
Port Item Id. The item port id.
 Output Arguments The property set returned will have the possible domain item product Ids as properties, each with the value 0, as follows: < ProdId1="0" ProdId2="0" ... ProdIdn="0" /> |
