| Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs for the Complex Object Manager > GetPossibleValues Method
 This method retrieves selectable values from the configuration engine for an attribute. Input Arguments
ObjId. The unique identifier of the complex object root (for example, Quote ID).
RootId. The unique identifier of the complex object root (for example, Quote Line Item row id).
(Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
IntObjName. The name of the integration object.
Path. The Integration ID of the port to which this attribute is attached.
XA Id. The ID of the attribute for which the values need to be determined.
 Output Arguments The property set returned will have the possible values as the property names, as follows: < [PossibleValue1]="Val1" [PossibleValue2]="Val2"/> |
