| Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs to Set Product and Attribute Values > RemoveItem Method
 This method removes an item from the instance. Input Arguments
ObjId. The unique identifier of the complex object header.
RootId. The unique identifier of the complex object root.
(Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
Path. The path of the item.
 Output Arguments None. |
