| Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs to Set Product and Attribute Values > ReplaceItem Method
 This method replaces an existing item with the new item on a specified port, removing the existing item from the port and creating a new instance for new item.         Input Arguments
ObjId. The unique identifier of the complex object header.
RootId. The unique identifier of the complex object root.
(Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
Path. Integration Id of the existing product (which is going to be replaced by new product)
Name. The name of the new item.
Product Id. The new product id in S_PROD_INT table.
Prod Item Id. The ID of the new item (for example, ORIG_ID in S_PROD_ITEM table).
Port Item Id. The ID of the item's port (for example, ORIG_ID of the port in S_PROD_ITEM table).
Quantity. The new item quantity.
(Optional) AutoResolve. Automatically resolves port cardinality violations. The default is N.
(Optional) List Price. The item list price from Pricing Manager, which can be empty.
(Optional) Current Price. The current price from Pricing Manager, which can be empty.
(Optional) Parent Path. Integration Id of the parent item the port belongs to.
(Optional) Parent Display Name. Display name of the parent product. This parameter and the display parameters that follow would be used in logging error messages in case of error.
(Optional) New Child Display Name. Display name of the new child product.
(Optional) Port Display Name. Display name of the Relationship of the child product.
 Output ArgumentsNone. |
