| Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs for the Complex Object Manager > UnloadInstance Method
 This method removes the existing configuration session from memory. It must be called after synchronizing the instance at the end of the configuration session. Input Arguments
ObjId. The unique identifier of the complex object header.
RootId. The unique identifier of the complex object root.
IntObjName. The name of the integration object that was used to load the instance.
 Output Arguments None. |
