Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs for the Complex Object Manager > GetAllPorts MethodThis method retrieves a list of all ports and (possibly) their contents for a product. It gets all ports for a product but not for its child products. It retrieves the basic definition of the product and does not consider any current configuration session state, so every possible port is retrieved. Input Arguments
Output ArgumentsAll ports are returned as children of the output property set of type Port. Port information can be returned through GetProperty(). For example, GetProperty(Class Id). |
| Siebel Product Administration Guide | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
