Siebel Product Administration Guide > Siebel Configurator Version 6.x, 7.0 and 7.5 > Designing Rules and Logical Expressions in Version 6.x and 7.xThe version 6.x Basic Rule Designer, Logic Designer, and Advanced Rules Designer have been replaced by the Rule Designer in version 7.0 and 7.5. The Rule Designer provides a series of natural-language rule templates that you can use to create rules of any complexity. You can also create and save your own rule templates. The logical operators in the version 6.x Logic Designer are provided in picklists associated with the rule templates. A special rule template is provided to enter rules in Siebel Configurator Rule Language (renamed Rule Assembly Language in version 7.0 and 7.5). The operators and syntax in version 6.x Siebel Configurator Rule Language are supported in version 7.0 and 7.5. Table 52 maps version 6.x features to 7.0 and 7.5 for designing rules. |
| Siebel Product Administration Guide | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
