| Siebel Product Administration Guide > Multilingual Translations for Product Data >  Translating Configuration Rule Explanations
 Use this procedure to translate configuration rule explanations for a customizable product. To translate a configuration rule explanation
Navigate to the Administration - Product, then the Product Definitions view.
In the Products list, select and lock the desired customizable product.
In the Versions list, click the Work Space version.
Click the Constraints view tab.
In the Constraints List, select the constraint containing the explanation you want to translate.
From the Constraints List menu, choose Translate Constraint Description.
A dialog box appears that displays the rule explanation translations you have already created. In the dialog box, add a new record and complete the necessary fields, described in the following table.
    | Language | Displays the name of the language after you select the code. |
    | Code | Select a language code.  |
    | Description | Enter the translation of the description.  |  |
