| Siebel Product Administration Guide > Multilingual Translations for Product Data >  Translating Relationship Names
 You can translate relationship names for a product with components the following ways:
You can translate the relationship name at the Product Classes level, so all products in the class inherit the translation.
You can translate the relationship name at the Product level, so the translation applies only to that product.
 To translate a relationship name at the Product Class level
Navigate to the Administration - Product screen, then the Product Classes view.
Select and lock the desired Product Class.
In the Versions list, click the name of the Work Space version.
In the Structure list, select the relationship whose name you want to translate.
From the Structure list menu, choose Translate Relationship.
A dialog box appears that displays the relationship name translations you have already created. In the dialog box, add a new record and complete the necessary fields, described in the following table.
    | Language | Select a language code.  |
    | Relationship Name | Enter the translation of the relationship name for that language.  |  To translate a relationship name at the Product level
Navigate to the Administration - Product screen, then the Product Definitions view.
In the Products list, select and lock the desired product with components.
In the Versions list, click the Work Space version.
Select the relationship whose name you want to translate.
    | Language | Displays the name of the language after you select the code. |
    | Code | Select a language code.  |
    | Description | Enter the translation of the description.  |  |
