| Siebel Product Administration Guide > Configuration Constraint Template Reference >  Arithmetic Operators in Configuration Constraints
 An arithmetic operator allows you to perform an arithmetic operation on two items. If an operand is a product, the value refers to the quantity of the product in the solution.  The operands in the expression can be two items or can be one item and a constant. For example, you can increase the quantity of an item by a constant amount. If you specify an expression as one of the items, it must resolve to a quantity. If the expression resolves to true or false, then 1 is assigned to true, and 0 to false.  Results of calculations are handled differently for resources values than for product quantities. Calculation results for resources are expressed exactly, including a decimal point if necessary. Because product quantities represent discrete units, results involving them are rounded to the nearest integer. Table 18 shows the arithmetic operators.
Table 18.	Arithmetic Operators
    | Addition | A + B | Sum of A and B. A and B can be items or expressions. Result is floating point if A or B is floating point. |
    | Subtraction | A - B | Subtracts B from A. A and B can be items or expressions. Result is floating point if A or B is floating point.  |
    | Negation | -(A) | Additive inverse of A. Uses only one operand. A can be an item or expression. |
    | Multiplication | A * B | Product of A and B. Result is floating point if A or B is floating point. A and B can be items or expressions. |
    | Division | A / B | Quotient of A divided by B. Truncates ratio to integer if both A and B are integers. Result is floating point if A or B is floating point. A and B can be items or expressions.  |
    | Modulo | %(A, B) | Remainder of A divided by B. For example, %(1900, 72) results in 28. If A or B is floating point, the value is first rounded to the nearest integer; then the remainder is computed as for integers. A and B can be items or expressions.  |
    | Minimum | min(A, B) | Result is the smaller of A and B and is floating point if A or B is floating point. A and B can be items or expressions.  |
    | Maximum | max(A, B) | Result is the larger of A and B and is floating point if A or B is floating point. A and B can be items or expressions.  |
 Table 19 shows additional arithmetic operators that also take numeric operands and produce numeric results. Use them to control numeric accuracy or change numeric characteristics.
Table 19.	Additional Arithmetic Operators
    | Integer | int(A) | Truncates A down to an integer. For example, if the operand is 6.7, returns 6. A can be an item or expression. Useful only with properties.  |
    | Float | flo(A) | Converts A to a floating point. It is the same as multiplying the operand by 1.0. A can be an expression. |
    | Absolute value | abs(A) | Returns the absolute value of A. A can be an item or expression. |
    | Sign test | sgn(A) | Returns -1 if the quantity of A <0, 0 if A=0, 1 if A>0. A can be an expression. |
