| Siebel Product Administration Guide > Smart Part Numbers for Products with Attributes > Process of Creating Dynamically Generated Smart Part Numbers > Defining the Part Number Templates
 Next, define the part number template.  This task is a step in Process of Creating Dynamically Generated Smart Part Numbers. To define the part number template
In the Name field of the Smart Part Number record, click the name you entered.
The name is a hyperlink. The Part Number Method view appears.In the Part Number Template list, add a new record and complete the necessary fields, described in the following table.
    | Pre-Fix | Enter a static text that appears before all other parts of the smart part number generated by the application |
    | Attribute Name | Select the attribute for this section |
    | Post Fix | Enter a static text that appears after all other parts of the smart part number generated by the application |
    | Abbreviation Method | Select an abbreviation method for the attribute mapping |
    | Sequence | Enter a sequence. The sequence determines the order of the section in the part number. | Repeat Step 2 for each section you want to include in the part number.
