Table 3. Supported Upgrade Paths for Siebel CRM Version 8.1.1.14 on IBM DB2 for z/OS
Siebel 7.5.3 through Siebel 8.0 (SEA repository) |
- Full database upgrade.
- Two-step repository upgrade.
You must perform a two-step repository upgrade:
- Upgrade Siebel CRM version 7.5.3 through Siebel CRM version 8.0 (SEA repository) to Siebel CRM version 8.1.1 (SEA repository).
- Upgrade Siebel CRM version 8.1.1 (SEA repository) to Siebel CRM version 8.1.1.14 (SIA repository).
Siebel 7.5.3 (SIA repository) |
- Single-step upgrade.
- Perform a full database upgrade. A Development environment upgrade and a Production environment upgrade is required.
- You can directly upgrade to Siebel CRM version 8.1.1.14. It is a single-step upgrade and post-upgrade process.
- The New Customer repository, generated through a three-way repository merge, contains all the content from the Siebel CRM 8.1.1.14 Innovation Pack. For more information on repository merge, see Performing the Siebel Repository Merge.
Siebel 7.7.2 (SIA repository) |
Siebel 7.8.2 (SIA repository) |
Siebel 8.0 (SIA repository) |
Siebel 8.1.1.0 (SEA repository) |
Siebel 8.1.1.0 to 8.1.1.9 (SIA repository) |
- Patch installation.
- Incremental repository merge.
- Run Oracle Universal Installer (OUI) to apply the Siebel CRM version 8.1.1.14 SIA patch release.
NOTE: Siebel Innovation Pack content is not included in the patch release.
- If you intend to use new features included from the Siebel CRM 8.1.1.14 Innovation Pack, then you must import the Innovation Pack using incremental repository merge. For more information on incremental repository merge, see Performing the Siebel Incremental Repository Merge.
Siebel 8.1.1.10 (SIA repository) |
Siebel 8.1.1.11 (SIA repository) |
