Configure a bond interface using
two interfaces connecting to the NEM24p-0 and NEM24p-1 such that
the bond interface accepts both VLAN 300 and 301 traffic.
[Host-2]# cat /proc/net/bonding/bond0
Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
Bonding Mode: fault-tolerance (active-backup)
Primary Slave: eth7 (primary_reselect always)
Currently Active Slave: eth7
MII Status: up
MII Polling Interval (ms): 100
Up Delay (ms): 0
Down Delay (ms): 0
Slave Interface: eth6
MII Status: up
Speed: 10000 Mbps
Duplex: full
Link Failure Count: 5
Permanent HW addr: 00:1b:21:66:48:ec
Slave queue ID: 0
Slave Interface: eth7
MII Status: up
Speed: 10000 Mbps
Duplex: full
Link Failure Count: 11
Permanent HW addr: 00:1b:21:66:48:ed
Slave queue ID: 0
[Host-2]# ifconfig -a
bond0.300 Link encap:Ethernet HWaddr 00:1B:21:66:48:EC
inet addr:192.168.30.50 Bcast:192.168.30.255 Mask:255.255.255.0
inet6 addr: fe80::21b:21ff:fe66:48ec/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:374 errors:0 dropped:0 overruns:0 frame:0
TX packets:536 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:30622 (29.9 KiB) TX bytes:45960 (44.8 KiB)
bond0.301 Link encap:Ethernet HWaddr 00:1B:21:66:48:EC
inet addr:192.168.31.50 Bcast:192.168.31.255 Mask:255.255.255.0
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:39 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:2646 (2.5 KiB)
NEM24p-1 SEFOS# sh uplink-trailing group 20 detail
Uplink Trailing Group 20
Description: Uplink-trailing between NEM24p-1 & ToR72p-1
Admin Status: Enabled
Status: Up
Link State Change: Up 1 Down 0
Port Type Status
Ex0/1 uplink Up
Ex0/18 downlink Up
