Siebel Application Services Interface Reference > Application Services Interfaces > About Integration Object StructureIntegration objects are metadata structures that represent hierarchical objects using components and fields. For example, the Contact integration object might have the following components—Personal Address, Account, and Opportunity. Figure 5 shows a sample of the Contact integration object, and the integration object instance containing the data for Contact. The structure of integration objects includes:
For data synchronization services, there are two types of integration objects. For more information about data synchronization services, see ASI Data Synchronization Services. For more information about integration objects, see Integration Platform Technologies: Siebel Enterprise Application Integration. |
| Siebel Application Services Interface Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
