Siebel Applications Administration Guide > Configuring the Inbox > Universal Inbox Business Service Methods >
CreateInboxItem Method
This method creates multiple Inbox items. The name-value pairs are put into the Inbox Parameters table. Input Arguments
Table 27 lists the input arguments for this method.
Table 27. CreateInboxItem Method, Property Set, Type of InboxItemInfo
InboxName |
Yes |
This property is the name for the Inbox. |
InboxTypeName |
Yes |
This property is the name of Inbox type. |
InboxPartyId |
Yes |
This property is the party ID of the Inbox owner. |
ObjectId |
Yes |
This property is the object ID of the inbox item. |
InboxExpirationDuration |
No |
The duration is expressed in seconds. |
InboxUTCExpirationTS |
No |
This property is the UTC timestamp. |
Comments |
No |
None. |
ReplicationLevel |
No |
This property indicates whether this Inbox item must be routed when using remote databases. Select one of the following options:
- All. Indicates HQ, Regional, Local.
- Regional. Indicates HQ, Regional.
- None. Indicates HQ.
Output Arguments
Table 28 lists the output arguments for this method.
Table 28. CreateInboxItem Method, Property Set, Type of ItemOutput
InboxItemId |
This property is the row ID of the newly-created Inbox item. |
