Siebel Applications Administration Guide > Configuring the Inbox > Universal Inbox Business Service Methods >
CreateInboxOwner Method
This method creates multiple Inbox item owners for an Inbox item. If DeactivateOthers is true, then the method deactivates the current active Inbox item owners before creating new owners. The method searches as follows:
- InboxItemId
- ObjectId + InboxTypeName
Input Arguments
Table 29 lists the input arguments for this method for the property set.
Table 29. CreateInboxOwner Method, Property Set
InboxItemId |
No |
This property is the row ID of the newly-created Inbox item. |
ObjectId |
No |
This property is the object ID of the inbox item. |
InboxTypeName |
No |
This property is the name of Inbox type. |
DeactivateOthers |
No |
This property deactivates the current active Inbox item owners before creating new owners when the value is Yes (the default). |
Child properties |
No |
Multiple children are allowed. See Table 30. |
Table 30 lists the input arguments for this method for the child property set.
Table 30. CreateInboxOwner Method, Child Property Set, Type of InboxOwnerInfo
OwnerPartyId |
Yes |
This property is the party ID of the Inbox owner. |
OwnerPriority |
No |
None. |
OwnerQueueDuration |
No |
The duration is expressed in seconds. |
OwnerUTCDueTS |
No |
This property is the UTC timestamp. |
OwnerUTCStartWorkingTS |
No |
OwnerActionLIC |
No |
This property is the language-independent code. |
Output Arguments
Table 31 lists the output arguments for this method for the property set.
Table 31. CreateInboxOwner Method, Property Set, Type of ItemOutput
InboxItemId |
DeactivateOthers |
This property indicates whether or not the other owners have been deactivated. |
Child properties (OwnerInfoOutput) |
Multiple children can be returned. See Table 32. |
Table 32 lists the output arguments for this method for the child property set.
Table 32. CreateInboxOwner Method, Child Property Set, Type of OwnerInfoOutput
OwnerPartyId |
OwnerInfoId |
This property is the information ID of the Inbox owner. |
