Siebel Applications Administration Guide > Configuring the Inbox > Universal Inbox Business Service Methods >
DeactivateInboxOwner Method
This method deactivates an Inbox item owner and updates field values for that Inbox item owner. The method searches as follows:
- OwnerInfoId
- InboxItemId, OwnerPartyId
- ObjectId, InboxTypeName, OwnerPartyId
If there is SSASqlErrWriteConflict conflict, then clear the error message to show the error message on UI. Input Arguments
Table 48 lists the input arguments for this method.
Table 48. DeactivateInboxOwner Method, Property Set
ObjectId |
No |
This property is the object ID of the Inbox item. It is not updated, but is used for searching. |
InboxTypeName |
No |
This property is the name of Inbox type. It is not updated, but is used for searching. |
OwnerPartyId |
No |
This property is the party ID for the Inbox owner. The ID is not updated, but is used for searching. |
InboxItemId |
No |
This property is the row ID of the Inbox item. The ID is not updated, but is used for searching. |
OwnerInfoId |
No |
This property is the information ID for the Inbox owner. The ID is not updated, but is used for searching. |
OwnerPriority |
No |
None. |
OwnerActionLIC |
No |
This property is the language-independent code. |
OwnerComments |
No |
None. |
OwnerStartWorkingTime |
No |
This property is the UTC timestamp. To set to the current time, enter a value of Y, T, or TRUE. |
OwnerEndWorkingTime |
No |
