Siebel Applications Administration Guide > Configuring the Inbox > Universal Inbox Business Service Methods >
UpdateInboxOwnerInfo Method
This method updates field values for an Inbox item owner.
The method searches as follows:
  1. OwnerInfoId
  2. InboxItemId, OwnerPartyId
  3. ObjectId, InboxTypeName, OwnerPartyId
Input Arguments
Table 49 lists the input arguments for this method.
Table 49. UpdateInboxOwnerInfo Method, Property Set
Property Name
Required
Comments
ObjectId
No
This property is the object ID of the Inbox item. It is not updated, but is used for searching.
InboxTypeName
No
This property is the name for the type of Inbox. It is not updated, but is used for searching.
OwnerPartyId
No
This property is the party ID for the Inbox owner. It is not updated, but is used for searching.
InboxItemId
No
This property is the row ID of the Inbox item. The ID is not updated, but is used for searching.
OwnerInfoId
No
This property is the information ID for the Inbox owner. It is not updated, but is used for searching.
OwnerPriority
No
None.
OwnerActionLIC
No
This property is the language-independent code.
OwnerQueueDuration
No
The duration is expressed in seconds.
OwnerUTCDueTS
No
This property is the UTC timestamp.
OwnerComments
No
None.
OwnerStartWorkingTime
No
This property is the UTC timestamp. To set to the current time, enter a value of Y, T, or TRUE.
OwnerEndWorkingTime
No
Siebel Applications Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
