| Siebel CRM Assignment Manager Administration Guide Siebel Innovation Pack 2015 E24725-01 |
![]() Previous |
![]() Next |
View PDF |
Using Siebel Tools, you can modify existing assignment object definitions or create new assignment object and assignment criteria definitions in the Siebel repository. After you compile the changes, these definitions appear as criteria in the Criteria view or as skills in the candidate skills picklists in your Siebel Business Applications for assignment object selection.
Siebel Assignment Manager features that you can custom configure using Siebel Tools include:
List of assignment objects that can be assigned to assignment rules
List of attributes that can be incorporated in assignment criteria
Behavior of each available assignment object, including whether certain features are activated for the assignment object
Table and column mappings of assignment objects and attributes
Workflow policy component and workflow policy component column mappings of attributes used in assignment criteria
List of dynamic candidate objects for each assignment object
List of dynamic candidate component objects for each dynamic candidate (for team-based criteria)
Table 6-1 lists the various configuration tasks that you might need to perform before creating your assignment rules. The steps are presented in no particular order, and some might not be applicable for your needs.
Table 6-1 Basic Assignment Configuration Tasks
Note: In addition to the basic configuration tasks, you might find that you need additional configuration to meet your particular business needs. Configuration tasks other than the basic topics are explained in a separate chapter and might require you to have additional knowledge or skills to perform. For more information about advanced configuration tasks, see Chapter 10, "Advanced Siebel Assignment Manager Configuration." |
Before you can successfully configure Assignment Manager, you must have a thorough understanding of how to use Siebel Tools, Assignment Manager, and the Siebel Data Model. Also familiarize yourself with the basics of the underlying Siebel Business Applications architecture.
For information about:
Siebel Tools functionality, see Using Siebel Tools and Configuring Siebel Business Applications.
Siebel Business Applications architecture, see Siebel Deployment Planning Guide.
Workflow Manager functionality, see Siebel Business Process Framework: Workflow Guide. (Assignment Manager object types are related to Workflow Manager object types.)
Siebel Data Model, see Siebel Data Model Reference on My Oracle Support.
