Siebel Business Process Framework: Workflow Guide > Defining Custom Workflow Policies > Customizing Workflow Policy Objects >
Configuring a Custom Workflow Policy Object
This topic describes how to configure a custom workflow policy object.
To configure a custom workflow policy object
  1. In Siebel Tools, navigate to the Workflow Policy Objects list.
  2. Choose the Edit menu, and then the New Record menu item.
  3. Configure properties for the new record.
  4. In the Object Explorer, click Workflow Policy Components.
  5. Choose the Edit menu, and then the New Record menu item.
  6. Make sure the Primary property contains a check mark.
    CAUTION:  You must define only one record in the Workflow Policy Components list as the primary workflow policy component. You can add a check mark to the Primary property for only one record. For more information, see How Siebel Tools Indicates the Primary Workflow Policy Component.
  7. Add more workflow policy components, configuring relations to the primary workflow policy component, as required.
  8. In the Object Explorer, click Workflow Policy Component Col.
  9. In the Workflow Policy Component Columns list, add an object for each of the workflow policy components that you configured in Step 7.
Siebel Business Process Framework: Workflow Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
