Siebel Business Process Framework: Workflow Guide > Defining Custom Workflow Policies > Customizing Workflow Policy Objects >
Configuring a Custom Workflow Policy Component
The example in this describes how to configure a custom workflow policy component.
To configure a custom workflow policy component
  1. In Siebel Tools, in the Object Explorer, click Workflow Policy Object.
  2. In the Workflow Policy Objects list, query the Name property for Account.
  3. In the Object Explorer, expand Workflow Policy Object, and then choose Workflow Policy Component.
  4. In the Workflow Policy Components list, add a new record with a value in the Name property.
  5. Enter a value in the Source Table Name property.
  6. Enter a value in the Source Column Name property.
    The Source Column Name property creates a relationship between the workflow policy component you are currently configuring and the primary policy component.
  7. Identify the set of columns that you must monitor for the workflow policy component that you created in Step 4:
    1. Navigate to the Workflow Policy Column list.
    2. Identify predefined workflow policy columns that you can use.
      To use one a column, an activity must be assigned to it and Siebel Tools must not currently display it in the Workflow Policy Component Column list.
Siebel Business Process Framework: Workflow Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
