Siebel Business Process Framework: Workflow Guide > Developing Workflow Processes > Process of Planning Workflow Processes > Determining the Actions the Workflow Process Must PerformThis task is a step in Process of Planning Workflow Processes. You can determine the actions that the workflow process must perform. To determine the actions the workflow process must perform
Data Manipulation in a Workflow ProcessA workflow process operates on business objects and business components. It references a single business object. In the context of these data layer objects, Siebel CRM creates or updates data while the workflow process runs. A workflow process can modify the following data: Siebel Tools creates a set of predefined process properties when you create a workflow process. You can think of a process property as a local variable that is active while a workflow process instance runs. Siebel CRM can use the process property as input and output to various steps in a workflow process. The Process Instance Id is one example of a predefined process property. For more information, see Using Process Properties. Uses and Limitations of Actions That the Workflow Process PerformsTable 9 describes the uses and limitations of actions that the workflow process performs. Using the Business Service StepA business service step can run a predefined or a custom business service method. The following items are examples of predefined business services:
You can write a custom business service in Siebel VB or Siebel eScript. If you add a business service step, then you must define the business service, the business service method, input arguments, and output arguments for that step. Siebel CRM passes input arguments in a process property, business component data, or as a literal value. The following list includes some business services that a workflow process typically uses:
For more information, see Adding a Business Service Step, and Predefined Business Services. If you require specialized functionality, then you can define a custom business service that performs a specific action. You can define a business service in Siebel Tools or in the administration screens of the Siebel client. For more information, see Integration Platform Technologies: Siebel Enterprise Application Integration. Using the Siebel Operation StepThe Siebel operation step allows you to configure Siebel CRM to do database operations. For example: A Siebel operation step references a single business component. After you define a Siebel operation step, you can use the Search Specification property to locate the records that Siebel CRM must use or modify. Examples of a Siebel operation step include creating an activity if the user creates a new service request, or updating a comment field if a service request is open too long. For more information, see Adding a Siebel Operation Step. |
| Siebel Business Process Framework: Workflow Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
